Yes and no. For some of the use cases I read here it totally seems to make sense (as far as I can judge). From my own perspective not so much, though. Here’s why:
In contrast to qualified links page properties stored in the header are not contextual and not specific. I can neither create nor discover them in writing. Moreover, if there is more than one relationship modelled via page properties I cannot know or indicate which of these is meaningful in my note’s context. You need to model, manage, and keep all relationships in the specific page header rather than having them spelled out where they actually matter. This obstructs one of Logseq’s core features, namely emerging connections between notes within context.
I think that we have two significantly different – and moreover: conceptionally incompatible – mental models at play here in how we approach working with knowledge:
- Relational Database (RDB): distinct (semi-)structured objects of more or less similar types with specific key/value fields (modeled as tables) storing data and modelling relationships
- Graph: unstructured objects of varying types with relationships expressed as edges between graph nodes. (Nodes can have key/value properties, ideally storable anywhere in the node)
Several of the contributors here seem to approach Logseq from a RDB perspective and not from a note graph perspective. Fair enough. But if you approach a graph-based tool with a RDB perspective you won’t get far (and vice versa). You can observe similar tendencies in the Obsidian neighbourhood where people are using DataView to tweak the system into a classical database (with all relevant data stored as key/value table in the header rather than the note body). To me that’s like trying to swim faster by putting on the best running shoes because they work so well on land ![]()
TL;DR: If you need a RDB, use a RDB and not a graph. The only tool I know that does both fairly well is Notion. And it does so by encapsulating the RDB blocks and keeping RDB records and graph nodes separate from each other. That way you can interact with both using an appropriate interface etc. without shoehorning one concept badly into the other.
PS: I totally acknowledge that there’s a warranted need combining both models in one ‘Integrated Thinking Environment’, and being able to use the fitting one depending on which kind of content you deal with. I just strongly object against turning any decidedly graph-based tool into a mishmash that tries to do both at once – and consequently neither well because the fundamental models involuntarily are clashing. That said: how about following Notion in that respect and implementing an RDB model on a block basis (perhaps using CSV instead of MD for storage)?
