**"$=$" means: Always equal**
**"$\neq$" means: May or may not be equal**
this is the code and above is the rendered output. I checked with claude.ai and it say’s it is written in correct syntax then why it is not rendered correctly ?
$\mathbf{"="} \textbf{ means: Always equal}$
$\mathbf{"\neq"} \textbf{ means: May or may not be equal}$
Welcome. Here is one more option:
"$\boldsymbol{=}$" **means: Always equal**
"$\boldsymbol{\neq}$" **means: May or may not be equal**
Hey, thanks a lot to both of you for the solutions! While both work just fine, I gotta say @etc’s approach looks a bit more appealing to me. Appreciate you taking the time to help out!
