First a caveat, no I don’t use timetracking (anymore).
:feature/enable-timetracking? false
;; logbook configuration.
:logbook/settings
{:with-second-support? false ;limit logbook to minutes, seconds will be eliminated
:enabled-in-all-blocks false ;display logbook in all blocks after timetracking
:enabled-in-timestamped-blocks false ;don't display logbook at all
How I have come to use the logbook:
When you have a repeating task, it will generate a logbook.
- TODO [#X] 🌟 Wajas : Daily Pear game
SCHEDULED: <2024-04-19 Fri .+1d>
collapsed:: true
:LOGBOOK:
* State "DONE" from "TODO" [2023-09-30 Sat 07:48]
* State "DONE" from "TODO" [2024-04-18 Thu 08:42]
:END:
Yes there’s a line for each day between those two dates.
Then on my journal page I have a query to get the tasks I completed that day. Specifically the tasks that repeat daily.
- #+BEGIN_QUERY
{:title [:mark "✅ Dagelijkse taakjes"]
:inputs [:query-page]
:in $ ?page
[?p :block/name ?page]
[?p :block/journal-day ?dag]
[(str ?dag) ?strdag]
[(subs ?strdag 0 4) ?jt]
[(subs ?strdag 4 6) ?mt]
[(subs ?strdag 6) ?dt]
[(str "* State \"DONE\" from \"TODO\" [" ?jt "-" ?mt "-" ?dt) ?strtodo]
[(str "* State \"DONE\" from \"DOING\" [" ?jt "-" ?mt "-" ?dt) ?strdoing]
[?b :block/priority "X"]
[?b :block/marker _]
[?b :block/content ?c]
(or
[(clojure.string/includes? ?c ?strtodo)]
[(clojure.string/includes? ?c ?strdoing)]
:result-transform (fn [result] (sort-by (fn [r] (get r :block/content)) result) )
:view (fn [result]
(for
[r result
:let [c (get r :block/content)]
:let [line (first (str/split-lines c))]
:let [clean (str/replace (str/replace line "[[" "") "]]" "")]
:let [item (str/replace (str/replace (str/replace clean "TODO " "") "[#" "") "] " " : ") ]
[:li item]
:group-by-page? false
:breadcrumb-show? false
The problem:
As of today the above task mentioned has become too big and now Logseq displays the error that the block cannot be edited anymore.
I have two options for this:
- Expand the config option to allow more text in a block, and wait for this error to occur again in the future.
- Delete/move entries from the logbook to make the block smaller, lose/move my logging, and wait for this error to occur again in the future.
What I would like to see:
It would be nice to have some sort of (automatic) archiving feature.
So that,
- I keep my records for my journal queries
- I don’t need to manually deal with an ever expanding logbook across multiple tasks
a. As this will happen for any of my repeating tasks, given time.
