What I am trying to do is a bit messy, but not completely dysfunctional. Here is what I do know for a fact:
:with-second-support? true; default false; limit logbook to minutes, seconds will be eliminated
:enabled-in-all-blocks false; display logbook in all blocks after marked with now or doing
:enabled-in-timestamped-blocks true;
:feature/enable-block-timestamps? true
My vanilla Desktop Logseq is set up to calculate the time interval, but the unit is always s which is mostly wrong. Does Mobile behave any less unintuitively?
This is my child’s computer so I will try to capture what is being done wrong:
Two little “tricks” I have learned is that you can highlight time without extra CSS or plugins with vanilla Desktop by using triangular brackets. The EBNF would be “<” int “:” int “>” or something to that effect, for example <07:30>
The other is if you can’t remember the start/end time of a block, but know you spent about 7.5minutes, just cheat and add
:LOGBOOK:
CLOCK: 7:30
:END:
But I do not recommend it. My Logseq has crashed several times today.
