I have finish the API Key setting, but logseg-zoteroloca-plugin: Connection error Status: 403 Response: Local APl is not enabled. how to deal with it.
Hmm you may be mixing up the two instructions for the native Zotero integration and the plugin.
You can try following the instructions here instead: logseq-zoterolocal-plugin/README.md at main · benjypng/logseq-zoterolocal-plugin · GitHub
