Hi,
Up until now I was taking my notes with Nebo on android, which is great. It has quite some limitation, especially the integration with desktop.
I recently started to use logseq myself on the desktop and I really love it, especially the possibility to link pages between each other, and the organization possibilities.
But now that I’m trying to use it on my tablet, it doesn’t work well with stylus. For the drawing I can use excalidraw, which work fine, but I would like to be able to write with the stylus and some text recognization(like in nebo) and have it integrated in my bullet points.
Is there a way to do it? Or is it just not implemented?
I’m using a galaxy s tab 8 pro.
