Logseq autosync to gitcloud and phone missing Link Repository to Folder
Desktop Logseq 0.10.7 to git cloud autosync works.
iPhone X iOS 16.3.1 using app Working Copy 5.9.6 syncs to git cloud
(I have pulled the git cloud Logseq data, which was pushed from the Desktop Logseq file), but fails to autosync.
I’ve found this video to be closest, but at 2:14 the process to autosync to iPad has a step ‘Link Repository to Folder’, which does not appear on the iPhone?
The options I see available in iPhone X iOS 16.3.1 → Working Copy 5.9.6 paid app → Repositories → hold down Logseq repository → select Share
→ here I should see Link Repository to Folder?
However I only see the following options:
Copy Path
SSH Upload
SSH Command
Share Zip Archive
Share workdir Archive
Share .git Archive
Share Universal Link
New Quick Note
Add Tage
Save to Files
Bitwarden
Save in Keep
Process in Working Copy
Edit Actions…
If I select Edit Actions… I see a new page with options:
Copy Path
SSH Upload
SSH Command
Share Zip Archive
Share .git Archive
New Quick Note
Add Tage
Save to Files
Bitwarden
Save in Keep
Sync computer to git cloud:
Git: version control system that tracks changes.
Only Desktop or Phone app open at 1 time, otherwise git sync might mess up.
1. Install git:
check:
Computer Linux Mint 21.3 Virginia Cinnamon → Terminal → $ git --version → select Enter → output: blank →
install:
$ sudo apt install -y git → select Enter →
check:
Terminal → $ git --version → select Enter → output: git version 2.34.1.
1.1. set git username:
Desktop → Terminal → $ git config --global user.name “<username (eg nickname, first name only, but not full name)>” (tip: best practice code is to replace <fillerText> and delete < >) → select Enter →
check:
git config --global user.name → select Enter → outputs username.
1.2. set commit email address:
Unsure why, skip for now?
Desktop → Terminal → $ git config --global user.email “<emailAddress>” → select Enter → git config --global user.email → select Enter → outputs email.
1.3. git cloud account sign in:
Github has a free student pack, handy for sync app Working Copy.
https://github.com → Sign in → enter username → enter github.com password →
create repository:
Github Dashboard → select + sign (Create new…top near right) → select New repository → Owner → Repository name: enter repository name, logseq-repo (don’t use Logseq, as this will confuse sync setup) → Description: logseq-repo repository is viewed in Logseq desktop app, Logseq and Working Copy phone app directories → select Private → tick Add a README file (so git cloud has a file to start pushing and pulling) → select Create repository.
2. Clone repo to computer:
2.1. github:
copy repo URL:
Github Dashboard → select repository logseq-repo → Local → Clone → HTTPS → https://github.com//logseq-repo.git → select Copy url to clipboard (double squares icon) → Copied!
2.2. linux mint:
Linux Mint 21.3 Virginia Cinnamon 64-bit (LM 21.3) → Terminal → navigate to your preferred directory for Logseq’s git repository (maybe ~/Documents?) → ~/Documents$ git clone <paste address copied from github repository (https://github.com/username/repositoryName.git)> → select Enter → enter github username: → select Enter → enter github password: → select Enter → ls → select Enter → output: logseq-repo (new git directory).
check cloned repo data:
LM 21.3 → Terminal → $ cat ~/Documents/logseq-repo/README.md → select Enter → output: description, from cloned repo.
credentials added automatically:
Auto store for auto push/pulls.
LM 21.3 → Terminal → $ git config --global credential.helper store → select Enter → git pull → select Enter → output: Already up to date.
2.3. auto sync from computer Logseq to git cloud:
add files:
post-commit and pre-commit to ~/Documents/logseq-repo/.git/hooks with your favourite editor
or
GitHub - charliie-dev/Logseq-Git-Sync-101: This repo aims to help Logseq users to sync their data with Git and GitHub. → select Code → select Download ZIP → select Save → extract the downloaded Logseq-Git-Sync-101-main.zip → open ~/Downloads/Logseq-Git-Sync-101-main/git-hooks → move post-commit and pre-commit to ~/Documents/logseq-repo/.git/hooks/ →
permissions:
make post-commit and pre-commit executable files Terminal:~/Documents/logseq-repo/.git/hooks$ chmod +x ./post-commit && chmod +x ./pre-commit → select Enter.
check:
Terminal → $ ls -al ~/Documents/logseq-repo.git/hooks → select Enter → output: -rwxrwxr-x (previously -rw-rw-r–).
2.4. download Logseq:
Download and install from LM 21.3 software manager → open Logseq (Release 0.10.7) → select Add a graph (top near right) → select Choose a folder → Portal/File Manager opens → select ~/Documents/logseq-repo (logseq-repo highlighted, don’t go into the logseq-repo directory) → select Select.
check:
Directory should now include directories: journals, logseq, pages and file README.md → open README.md to see cloned repo description.
logseq settings:
Logseq Desktop → select More (top towards right, ellipse icon) → select Settings → select Version control → enable Enable Git auto commit → enable Git commit on window close → Git auto commit seconds: 60 → select X to close window.
check auto sync:
Open Logseq Desktop → in Logseq Journals: type test<YYYYMMDDhhmm> → wait 60 seconds → refresh github.com/username/repository → select journals → select YYYY_MM_DD.md → output: testYYYYMMDDhhmm, matching the Logseq Desktop journal text.
Sync phone to git cloud:
Close Logseq on Desktop.
1. Install Logseq app:
iPhone X iOS 16.3.1 (phone) → open App Store → Search: logseq → select logseq → find Logseq Productivity → select Download → select OPEN (automatically creates a Logseq directory in Files app → iCloud Drive and On My iPhone).
2. Install Working Copy 5.9.6 app (does free app work?):
Paid Working Copy app $29.99 lifetime might be needed
or
Free student pack: https://education.github.com/pack → select Sign in → select Students → select Get Your Student Developer Pack → navigate to Working Copy → select Get access by connecting your GitHub account on WorkingCopy → iPhone → install Working Copy app → iPhone browser → workingcopyapp.com/education/verify/ → select ‘here’ to verify student status → Working Copy app opens → select Settings → Colour Scheme → select Dark → new page opens asking for payment for Dark → wait for processing and app shows ‘firstName is registered as a student’ and app is fully paid.
Phone → select App Store → Search: enter working copy → select working copy - git client → select download → select OPEN →
2.1. add clone repository:
Working Copy app → Repositories: select + (near top right) → select Clone repository → Clone repository: select GitHub → Clone repository: select Sign In →
2.2. sign in:
Phone → Working Copy → github.com → Username or email address: enter github account email address → Password: enter github account password → select Sign in → Authentication code: enter MFA authentication code → select Verify →
alternative:
select URL → enter URL (field above URL button): git@github.com:<gitHubUserName/gitHubRepositoryName>.git (<gitHubUserName>/Logseq) → select Clone → Logseq data should appear from GitHub.
2.3. clone:
Phone → Working Copy app → Clone repository → GitHub → Private → select logseq-repo git@github.com:<githubUsername>/logseq-repo.git → Clone repository: select Clone → Connecting… → logseq-repo repository data should appear, cloned from GitHub cloud.
2.4. check clone is correct:
Phone → Working Copy app → Repositories → logseq-repo (cloned repository)-> select journals → main → select YYYY_MM_DD.md → output: - testYYYYMMDDhhmm (data cloned from the git cloud account repository logseq-repo, in turn pushed from Logseq Desktop to git repository logseq-repo).
3. Connect Working Copy to a new phone sync directory:
Phone → Working Copy → Repositories → select cloned repository logseq-repo → logseq-repo: select Repository Status and Configuration (3rd row from top) → logseq-repo: select logseq-repo down arrow/caret (top, right of text logseq-repo) → select Link Repository to → select Directory → some page opens from the phone Files app Browse tab → navigate to Files app top page, Browse (select Back, top left) → Browse → Locations → select On My iPhone → select Logseq directory → Logseq: hold down in a blank space (Folder is Empty) → select New Folder → enter new name: SyncLogseqViaWorkingcopyWithGit (different name from the cloned repository logseq-repo) → select done → SyncLogseqViaWorkingcopyWithGit Browse tab: select Open (top right).
check new directory:
Phone → open Files app → Browse → Browse tab → navigate to Files app top page, Browse (select Back, top left) → Browse → Locations → select On My iPhone → select Logseq directory → select SyncLogseqViaWorkingcopyWithGit directory → select journals → select YYYY_MM_DD → output : - testYYYYMMDDhhmm (from cloned git cloud repository).
4. Logseq app new graph:
4.1. create a new graph:
Phone → open Logseq → Welcome to Logseq! → select Create a new graph → What’s the graph name? Test → iCloud sync disabled (option button with white hard to see text) → select Create →
4.2. set location to sync directory:
Files app → Browse tab → navigate to Files app top page, Browse (select Back, top left) → Browse → Locations → select On My iPhone → select Logseq directory → Logseq: SyncLogseqViaWorkingcopyWithGit (created by you just before) and TestYYYYMMDDhhmm (cloned repository to Working Copy from git account) → select SyncLogseqViaWorkingcopyWithGit directory (directory linked to Working Copy) → select Open.
4.3. check new graph:
Phone → open Logseq → journal showing Mon DDxx, YYYY → - testYYYYMMDDhhmm (data from cloned logseq-repo) → enter: Test<YYYYMMDDhhmm> (current time, later than original logseq-repo) → open Files app → navigate to Files app top page, Browse (select Back, top left) → Browse → Locations → select On My iPhone → select Logseq → select SyncLogseqViaWorkingcopyWithGit → select journals → select most recent file (previous test file should also be in journals) → text should show data from iPhone app Logseq’s new graph: - TestYYYYMMDDhhmm (original logseq-repo test) and - TestYYYYMMDDhhmm (current time, later than the original logseq-repo).
5. Auto sync open and closed app:
5.1. pull data to phone:
Phone → Shortcuts app → select Automation (bottom) → select + sign (top right) → New Automation: select Create Personal Automation → New Automation: select App → New Automation → When → Is Opened is ticked → Is Closed is unticked → App: select Choose → Choose App: select Logseq → Choose App: select Done → New Automation: select Next → Actions: select Add Action → Actions: select Apps → Actions: select Working Copy → Actions: select Pull Repository → Pull from: select Repository → Choose: select logseq-repo (not welcome to working copy) → Actions: select Next → New Automation: disable Ask Before Running → select Don’t Ask → enable Notify When Run → New Automation: select Done.
5.2. stage for commit:
Phone → Shortcuts app → select Automation (bottom) → select + sign (top right) → New Automation: select Create Personal Automation → New Automation: select App → New Automation → When → untick Is Opened → tick Is Closed → App: select Choose → Choose App: select Logseq → Choose App: select Done → New Automation: select Next → Actions: select Add Action → Actions: select Apps → Actions: select Working Copy → Actions: select Stage for Commit → Stage: select Path → enter * → in: select Repository → Choose: select logseq-repo (not welcome to working copy) → Actions: select Next → New Automation: disable Ask Before Running → select Don’t Ask → enable Notify When Run → New Automation: select Done.
5.3. commit:
Phone → Shortcuts app → select Automation (bottom) → select + sign (top right) → New Automation: select Create Personal Automation → New Automation: select App → New Automation: → When → untick Is Opened → tick Is Closed → App: select Choose → Choose App: select Logseq → Choose App: select Done → New Automation: select Next → Actions: select Add Action → Actions: select Apps → Actions: select Working Copy → Actions: select Commit Repository → Commit: select Repository → Choose: select logseq-repo (not welcome to working copy) → with: select Message → type in: Auto commit from iOS → select done → Actions: select Next → New Automation: disable Ask Before Running → select Don’t Ask → enable Notify When Run → New Automation: select Done.
5.4. push to remote:
Phone → Shortcuts app → select Automation (bottom) → select + sign (top right) → New Automation: select Create Personal Automation → New Automation: select App → New Automation → When → untick Is Opened → tick Is Closed → App: select Choose → Choose App: select Logseq → Choose App: select Done → New Automation: select Next → Actions: select Add Action → Actions: select Apps → Actions: select Working Copy → Actions: select Push Repository → Push: select Repository → Choose: select logseq (not welcome to working copy) → to remote: select arrow → Remote Default → Actions: select Next → New Automation: disable Ask Before Running → select Don’t Ask → enable Notify When Run → New Automation: select Done.
5.5. check auto sync:
Phone → open Shortcuts → select Automation tab (bottom) → should show:
When “Logseq” is closed. Stage for Commit
When “Logseq” is closed. Commit Repository
When “Logseq” is closed. Push Repository
When “Logseq” is opened. Pull Repository
Test 1:
Phone → open Logseq → notification: Opened “Logseq” Running your automation → check journal has 2 lines testYYYYMMDDhhmm (cloned from git cloud repository) and TestYYYYMMDDhhmm (text from 2nd test) → add 3rd line Test<YYYYMMDDhhmm> → close Logseq → notification: Closed “Logseq” Running your automation (x3) → open Working Copy → Repositories → logseq-repo error: main, ahead of remote by 1 commit → open Logseq → notification: Opened “Logseq” Running your automation → close Logseq → notification x3: Closed “Logseq” Running your automation → open Working Copy → Repositories → logseq-repo Application, main (error solved: ahead of remote by 1 commit) → open github → remote repo shows 3 lines.
Test 2:
Phone → open Logseq → enter 4th line Test<YYYYMMDDhhmm> → close Logseq → allow 60 seconds to check git cloud account, by refreshing the web page → desktop → open Logseq → allow 60 seconds to pull git cloud account repository → journal should show 4th line from iPhone Logseq.
Test 3:
LM 21.3 → open Logseq Desktop → journal → add 5th line: test<YYYYMMDDhhmm> → open github web page → 5th line should show → open phone → open Logseq → 5th line should show.
Sources:
Code and earlier guide:
Student free app:
Video (iPad):
https://www.youtube.com/watch?v=c2HrdSOoVD8 https://www.youtube.com/watch?v=FUSlKE19K5I
