Logseq DB and advanced queries
Sure, the DB version is not released yet, so my questions can only be a problem of the alpha versions. I’ve downloaded the DB version recently, and now I am not sure how permanent the changes are in regard to advanced queries:
  1. It seems that using properties is no longer available in advanced queries. At least, I could not make the basic example work, which works in the stable version:
{:title [:h2 “Programming languages list”]
(property ?b :prop "value")]}
Also, I don’t see properties in block data with developer tools.
Am I missing something? Maybe now there is another way to build queries with properties? Or would it be better to use new tags instead?
  1. The :view command also seems not to be working in new queries. But actually, I’ve never mastered it, so, again, it can be my skills issue. But I would like to check if it’s just me.
Hi @sorgel
The advanced query still works, but note that some schema changes were introduced.
They are documented in:
Example of Advanced Query:
```clojure
{:query [:find (pull ?b [*])
[?b :user.property/Player-bEMnJKfg ?player]
(or [?player :block/name “player a”]
[?player :block/name “player c”]]
If you do not see the block data, go to Logseq Settings >> Advanced >> Enable Developer Mode
`:view works, but :result_transform needs a bit of work
Thank you so much! I tried not to miss something obvious, but somehow managed to do this.
Maybe that will help someone in future: I can mess something, but it looks like the right way to access the property value is by :block/title, not :block/name.
So in my case this does work:
[?b :user.property/test-c_eBb5ly ?a]
[?a :block/title “rrr”]
And this does not:
[?a :block/name “rrr”]
Also dev tools suggest using the title instead of the name
