Logseq DB and md files
Hi,
in the corporate environment, it is often forbidden to install software. This is also the case for me. That’s why I use logseq privately and edit the md files with a text editor at work. After making changes, I synchronize the files. It’s not ideal, but it works.
Does this also work with Logseq DB?
Thanks for an answer
Logseq DB has a Web version you can run in the browser. Try it out: test.logseq.com
