Logseq Espanso Integration - Generating Espanso yaml out of Logseq blocks!
Scripts for generating Espanso yaml configuration out of Logseq blocks
Motivation
  • Espanso yaml configuration is somewhat not that user friendly (well, as opposed to logseq blocks for sure..)
  • Logseq can hold variety of items types (journal, tasks, etc) including snippets (mostly logseq templatess and code snippets inside code blocks to be copied with “Copy Code” plugin)
Why not combine them and mark those “snippets” blocks with special espanso attributes and generate yaml match files?
For day to day snippets cross applications (and platforms) thanks to Espanso!
You hear right - This project providing scripts for generating espanso yaml configuration from logseq blocks!
Demo
Usage
Two structure types are supported
inline replacement
espanso-regex:: <espanso trigger>
espanso-label:: <espanso label, optional, to be displayed with espanso search bar>
espanso-filename:: <yaml filename (.yml ending is optional) , optional, default to logseq.yml>
espanso-replace:: `<replace string surronding by backticks>`
e.g.
espanso-regex:: ;username
espanso-label:: my user name
espanso-filename:: personal
espanso-replace:: `bluckholl`
child code block replacement
    <replace lines>
e.g.
espanso-regex:: ;qblocked
espanso-label:: blocked processes
espanso-filename:: queries.yml
  • SELECT *
    FROM sys.sysprocesses
    WHERE blocked <> 0
Generating espanso yaml files
  • ctrl s a must for saving logseq changes to transit db
  • Running LogSeqToEspansoYaml.ps1 with your logseqGraph
    Bat file for easy run this convertor
     `"%PROGRAMFILES%\PowerShell\7\pwsh.exe" <Path>\LogseqEspansoIntegration\LogSeqToEspansoYaml.ps1 -logseqGraph "<Your Graph>"`
Installations
