Logseq graph in cryptomator vault
I have installed logseq from snap package and my note or graph data should be saved encrypted with cryptomator.
The problem is there are a lot of threads left active when I check with lsof.
In the default setup Logseq snap version with a local folder (colums cuttet):
Logseq    6622                /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6699 sandbox_i /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6702 ThreadPoo /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6703 ThreadPoo /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6704 ThreadPoo /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6705 ThreadPoo /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6706 Chrome_IO /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6707 MemoryInf /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6708 Logseq    /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6709 Logseq    /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6710 Logseq    /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6711 Logseq    /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6712 Logseq    /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6713 tokio-run /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6714 tokio-run /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6715 tokio-run /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6716 tokio-run /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6717 tokio-run /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6718 tokio-run /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6719 tokio-run /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6720 tokio-run /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6736 Bluez\x20 /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6737 CrShutdow /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6740 inotify_r /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6741 ThreadPoo /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6742 Composito /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6743 VideoCapt /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6744 Logseq    /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6751 ThreadPoo /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6752 pool-spaw /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6753 gmain     /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6767 CacheThre /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6817 Logseq    /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6818 Logseq    /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6819 Logseq    /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6820 Logseq    /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
Logseq    6622 6821 gdbus     /home/user/snap/logseq/4/.config/Logseq/search/logseq_local__home_user_Downloads_test-notes
What is VideoCapt and tokio-run?
When my graph folder is inside a cryptomator mounted folder (FUSE mount):
In lsof are multiple xdg-document-portal connections to my graph data, even after closing logseq. The cryptomator vault is blocked.
After reopening logseq, it is complaining about missing graph data, somewhere in /run/user/****/doc/***, it seems to be another random mountpoint.
