Logseq iOS not detecting changes
I am having an issue with the iOS version of logseq. More often than not it will not detect changes to the files and I have to manually do a refresh.
The files are syncing fine, iCloud is doing its job, logseq simply does not detect the changes. I can see the changes if I look at the files manually with files but they are not shown in logseq.
I am using the default Logseq iCloud folder so that should not be an issue.
I have tried reinstalling the app also, but to no avail. Any idea what I could do other than manually refresh? Logseq should be doing checks every time it is focused.
It seams that if it detects a change to the file from my Mac while the iOS app is open, it updates fine. It when the app is loading or coming out of sleep that it won’t update the synced changes.
