Hi
I was just wondering, is there a way to open LogSeq in a specific directory on startup with the necessary folders required (like journals, pages, assets and logseq - I can ensure I have them in that folder) without having the users to select the folder through the File Explorer GUI?
I was looking into the code. Ideally I would want to give the folder’s path WITHOUT the window.showDirectoryPicker(), would that be a possible solution?
I’m okay to provide more context if required as well
Any kind of help is appreciated
Thanks!
