The exported version of Logseq is just assets of a static website, with the app and your data bundled together, serving publicly to the web browser (when deployed). As a result, it may not be suitable for password-protected if I understand your use case correctly.
I will try deploy to Netlify later. It should work the same as GitHub pages or Vercel though.
Hey @junyu thanks for the reply. I haven’t been able to achieve deployment from Netlify would love to know if you managed to achieve it. Keep me updated if you can, really appreciate the help
Thanks @digitalknk interesting. Could it be because I did “New Site for Git” I’m deploying from my files in Github, did you do it like this, or did you uploaded the folder directly into Netlify?
