I just installed and tried to use this chrome extension that should allow me to do a quick capture of the web-page that you are currently at and send it immediately to my open Logseq graph:
Sadly, it doesn’t work for me. I see from the reviews (some also very recent, from a few days ago) that it works for most users.
I also tried this workaround, that sadly doesn’t work for me either (but seems to work for most people):
Changing browser (Chrome, Chromium, Firefox, Brave) didn’t change the outcome.
Then I remembered that I have an annoying issue to login to Logseq sync due to the fact that I’m using it from the Appimage on Debian, and the intended workflow from the browser couldn’t really access to the application. I guess this could be a similar issue.
The fix for the login issue was quite complex, but at least one-off…I’m skeptical there may be a one-off fix to this…but maybe?
Thank you, you are right, it’s a more general problem with any kind of Logseq-link.
Sorry for misattributing it to the specific plugin: I just didn’t notice it until I tried to use your plugin (great one btw, thanks for your work!).
May I ask if somebody has a link to an up-to-date fix to links on Debian? I followed a bit this issue and its link but I’m a bit confused about the state-of-the-art-fix:
