Logseq-reference-style on linux
Hi everyone, I’m just starting with logseq. I want to now how to plugin logseq-reference-style on linux Debian 11? (Logseq-linux-x64-0.9.8.AppImage)
Hi fellow Linux user!
In case you don’t have the plugin system enabled (names may be a bit different, I don’t use Logseq in English):
  1. Click on the menu on the right in the toolbar at the top
  2. Click “Settings”
  3. Click on “Features”
  4. Toggle “Plugin system”
Once you have plugin system enabled, you can install a plugin with:
  2. Click “Plugins”
  3. Click on the second tab “Library”
  4. Use the search box on the right to search for “References Styles”
  5. Click “Install”
Nothing Linux-specific here. If in the future you need help with something Linux-specific, make sure to add a Linux tag to you post, because I monitor new posts with that tag.
Hi @alex0 ,
The pluging system is already anabled, and logseq-references-styles installed, but it does not work.
Just in case, may mother language is spanish so I’m using logseq in my own.
Thanks for your help and support.
