As Logseq plans to drop support for GitHub integration after the mobile release.
Since I like the current stable version of Logseq (v0.5.5), I made some theme changes to it, and the GitHub integration is quite convenient. So I independently deployed the latest version of Logseq, including front-end, back-end, database, S3 storage, and other services, which can be interpreted as a clone of the current Logseq web version.
If you also like this web version, you can use this website logseq.xyz.
I have posted the changes and deployment instructions to this Repo, so if you want to deploy your own Logseq, you can follow these instructions.
Finally, thanks to Logseq for its open-source spirit and contribution to knowledge management, thank you!
