I’ve loved using Logseq, but updates since 9.12 have “stalled out” on my computer–type a character and then wait 4 seconds for it to appear. Can’t work with it. Typing stalls.
If I quit and reload, same thing. If I switch to later or latest updates, same thing.
If I shutdown and reboot my computer, Logseq will work again–for awhile. Then freezes. Have to force quit it.
I do use sleep/resume feature on my Mac Mini. I suspect Logseq doesn’t like that, can’t live with that.
I feel I have to switch to another software program to get my work done.
Noteplan works fine. But doesn’t have the flexible outline features that Logseq has.
Logseq worked quite well for me up until the many recent updates. Post 9.1.
Is this a programming issue, or is there something I can do on my end?
