Hi, thanks for this. I have re-tested and it seems the issue is that Logseq isn’t loading the custom.js; after make a change to it & re-opening Logseq I do not get the popup.
The file is in .\logseq\custom.js, so this seems correct, is there anything else I can check? I do have 2 separate graphs, so I tried unlinking the other one in case that was causing some sort of conflict, but still no luck.
