Macros to insert icons, buttons and more
Intro
Logseq internally uses Tabler Icons. You can browse its website to find an icon and copy its code:
Icon macro
Here there is a macro to be added in your config.edn to easily add those icons in your notes:
"i" "[:span {:class ti} \"&#x$1 \" ]"
Then in your notes you can use the syntax {{i code}}. Result:
Button macro
Here there is another macro, this one adds a label to the icon and a URL:
"b" "[:a {:href \"$2\"} [:span {:class ti} \"&#x$1 \" ] \"$3\"]"
Usage: {{b code, URL, Label}}, for example {{b eaad, http://example.com, Label}}. Result:
To point to a page instead the URL must be like this: {{b eaad, #/page/Page name, Label}}
Special button example: GitHub issue
You can also define specific buttons, for example here there is a macro to create a link to a GitHub issue:
"bug" "[:a {:href \"https://github.com/$1/issues/$2\"} [:span {:class ti} \"&#xea48 \" ] \"$2\"]"
Usage: {{bug org/repo number}}, for example {{bug logseq/logseq, 8623}}
Result:
nice workflow :muscle:
maybe it’s time for me to start using macroses finally ))
Wow, this is amazing! Thanks for sharing
FYI this plugin shows a little icon picker when you hit the selected shortcut. Highly more useful than searching for the code and copying it into a macro!
This method works pretty well for adding icons in the text. However, it doesn’t work well if you use the this macro for the icon of the properties of a page. Instead of the icon, the coder appears in the head of the page and the icon in the left panel. Is there any solution for that?
Before the code, add &#x
This is brilliant, I’ll be using this. Thanks!
As an alternative, the icon name can be used:
:ti "[:i {:class \"ti ti-$1\"}]"
Written as:
{{ti folder}}
It seems not all Tabler Icons are available, but you can search which ones are loaded with Ctrl-Shift-I, Sources tab, css. tabler-icons.min.css:
…which I realize now could just be typed as hiccup:
[:i.ti.ti-folder]
No need for a macro at all then.
If using this plugin, how can you use css to style the icon? In the inspector they just show up as a the same unicode character
