In Roam, the most recently entered blocks show up first in the autocomplete for block refs. This is extremely helpful, because you very typically want to block ref something you just wrote or are looking at (in a sidebar etc).
(You could technically also consider the visible block refs in the sidebar etc - Roam doesn’t do this, but I think it would also be helpful).
