I am using LogSeq for a while and really loving it. I also installed vim plugin that helped a lot with my productivity. However, due to my poor eye sight I am alway missing on LogSeq mode (view vs edit). Also, if the block has any childern when is collapsed.
I need to make visual effect more apperant. I read manual and think can be done with change in css files but having problem as what to change! Basically:
- I need to change background color (or other visual effect) depending if I am in edit or view mode.
 - Block’s icon/color be different if blocs has any children. For instance, have different color or show
 when there is children blocks.
What setting need to be changes.
Thanks a lot,
btw, I also installed awesome styler plugin but doesn’t seem to be any setting for that
