Mandatory Media Deletion Confirmation for All Blocks/Sub-blocks Logseq Database
Issue Description
Accidental deletion of embedded media (images, videos, PDFs) in any block/sub-block – including during active editing – causes permanent, unrecoverable loss. Crucially:
  • Ctrl+Z DOES NOT restore deleted media, even immediately after removal
  • Occurs with both existing and newly pasted/uploaded media
  • Highest risk during cursor navigation near media elements
Proposed Solution
Implement a non-bypassable confirmation dialog for ALL media deletions:
  1. Triggers:
    • Backspace/Delete keys targeting media
    • Right-click → “Delete” on media
    • Applies in ALL editing modes (new blocks, nested blocks, mid-sentence)
  2. Popup Text:
    Permanently delete this media? (Cannot be undone with Ctrl+Z)
    [ Cancel ]  [ Delete ]
  3. Key Coverage:
    • Media in unsaved/newly created blocks
    • Sub-block media (indented content)
    • Bulk media selection deletions
  4. Setting: Settings > Editor > "Always confirm media deletion" (enabled by default)
Why This Matters
  • No Undo Safety Net: Unlike text, deleted media cannot be recovered via undo history
  • Critical Data Preservation: Prevents irreversible loss of research/assets
  • Reduced Anxiety: Eliminates panic from “point-of-no-return” actions
Technical Notes
  • Detection: Flag deletions targeting ![]() or {{embed }} syntax
  • Undo Stack Bypass: Media deletion operates outside standard undo/redo flow
Sorry if I wrote something wrong, I compiled this post using a neural network. I don’t speak English. :slightly_smiling_face:
Well, imagine you’re studying your old notes, clicking on them, reading them, deciding to edit a bit, and accidentally deleting a block with a media file or deleting a media file while editing a block.
And that’s it! There is no media file that was there, and there is no way to return it! 🤷‍♂
Isn’t this a panic? :grin:
Because of what I perceived as the limitations in file management with Logseq I’ve never really sued it to manage my files but this is a pretty major hurdle to transitioning into that (which I do want to do).
Thank you for flagging it up.
I confirm the same thing on my macos. This is a very serious error.
@tienson Thank you so much for fixing such a serious bug that put me off using the program.
Maybe now I should think about returning to Logseq DB. :heart:
