Merge large .edn into existing logseq-db graph
I like to use the template with the Tana-style supertag functionality using Schema.org vocabulary in my existing logseq-db graph. This logseq_db_Templates_full.edn-file contains 8993 lines, 478 properties and 297 classes. This template is a .edn file. You can only import an .edn file into a new graph. I understand that an automatic merge is not possible, but what are good methods to do the merge?
