Missing Logseq iCloud folder is not recreated on re-install
I’m experiencing the same issue. I had played with Logseq couple months ago, possibly later I deleted its iCloud folder. Today I wanted to give LogSeq another try but I can’t it get to re-create the iCloud folder.
What’s surprising is that LogSeq does not appear in the list of applications requesting permission to store data on iCloud Drive – neither on iOS nor on macOS:
I had the same problem but I use both Mac and iPhone, and deleted the Logseq original folder twice, for the third run it didn’t create the “Logseq” folder, and my graphs didn’t want to synch with iCloud.
But I fixed the issue, by simply signing out of my iCloud from my iPhone. And the resign again. That refreshes or resets the iCloud synch. And after opening Logseq again it worked.
thanks, it works。 only this way works。
