Make it possible to navigate between journal entries, when they have been opened directly, e.g. via “All pages”? Roam uses the keyboard bindings Ctrl+Alt+p (previous) and Ctrl+Alt+n (next) for this.
Some graphical means would be fine too, e.g. pop-up a calendar widget.
I often times do /date, then navigate to a future day, then ctrl-o to go the future day, do some edits there, then alt < to go back to the previews page, esc to select the block with the date, backspace to delete it.
What a great suggestion. I would love for their to be an integrated calendar so that you can click on a day and it will open up the note. I find myself sometimes wanting to see what I did last month and it is a bit painful at the moment
