Should you be able to navigate popup drop downs with the up and down array keys or some other key combo? I can’t figure it out so I wind up clicking on it with my mouse.
These can be customized in the Settings > Keymap.
I tried using Tab/Shift+Tab and others but ultimately ended up using the arrow keys because there were some strange behaviors in some situations and it wasn’t worth it…
Thanks! That was already set up. I think I’ve figured out the theme I was using somehow broke it. But I didn’t know where to configure that so thanks for the information.
If you want some “critical” -to you- shortcuts to be safe from bugs/updates, then you can setup shortcuts inside config.edn
;; :shortcuts
;; {:editor/new-block "enter"
;; :editor/new-line "shift+enter"
;; :editor/insert-link "mod+shift+k"
;; :editor/highlight false
;; :ui/toggle-settings "t s"
;; :editor/up ["ctrl+k" "up"]
;; :editor/down ["ctrl+j" "down"]
;; :editor/left ["ctrl+h" "left"]
;; :editor/right ["ctrl+l" "right"]}
There should be some doc online with the whole list of :editor/WORD
syntax…
