I want to need some features urgently in logseq mobile, like calendar view, create table & make custom template. Is it possible, how to do?
Plugins are not supported on mobile so I think calendar view won’t be available.
You can create markdown tables manually not sure what you need.
Templates are just blocks with certain properties and again you can create them on mobile manually.
There is no way to do it urgently. Should read, learn, experiment:
- templates
- tables:
- query tables
- hiccup:
