Greetings,
I’m trying to upgrade from LogSeq 0.6.1 but I"m seeing different behaviour how DOING blocks are displayed in the NOW section.
In 0.6.1, DOING is shown as follows:
But in LogSeq 0.8.x (I tried 0.8.18 and the nightly on 18th of March 23) the nested DOING blocks are repeated multiple times as follows:
Is there a setting in config.edn I can change to restore the NOW block as it was in version 0.6? Or a setting where only the first Doing 1 and its children are displayed and not the subsequent 1 → DOING2, 1 → DOING 3 etc?
Love LogSeq and super thanks for any help offered.
Also, when I click on the first 1, the DOING 1 collapses and when I click on it it shows it twice:
After collapsing all of the DOING under NOW I get:
Now when I click to expand any of the DOING blocks, these are duplicated as follows:
Is this a known issue? Are there any settings or workarounds?
The NOW block is a query in the config file.
What you are seeing is that the query gets the blocks with DOING regardless of (most) anything else.
The extra 1 you see is actually the breadcrumb trail for that task.
Without breadcrumbs shown it will look like this:
We can however change the NOW query to only get the parent and not the children.
{:title "🔨 NOW"
:query [:find (pull ?h [*])
:in $ ?start ?today
[?h :block/marker ?marker]
[(contains? #{"NOW" "DOING"} ?marker)]
[?h :block/parent ?parent] ; add this line
(not [?parent :block/marker ?marker]) ; as well as this line
[?h :block/page ?p]
[?p :block/journal? true]
[?p :block/journal-day ?d]
[(>= ?d ?start)]
[(<= ?d ?today)]]
:inputs [:14d :today]
(sort-by (fn [h]
:collapsed? false}
Which gives this result:
See my comments in the query on what lines to add in your config file for this.
Works like a dream. Than you SO MUCH for this
