error: logseq has been removed, due to lack of maintenance and blocking the Electron 27 removal.
When trying to update my NixOS packages (on Darwin) I received this surprise ![]()
I think a bump to a new release that incorporates new electron version is necessary… but I do not think this will happen in the near future.
This is a known issue, also see:
A new release needs to be cut, which will happen when the feat/db branch gets merged back into main. There are a few blockers still for that. This is from @tienson in the Logseq Discord server:
There’re a few todos we want to be done before cutting a desktop release for the db version:
- Performance improvements, especially for app start time and large tables, this should be done in a few days.
- Markdown and EDN export support, this should be done in weeks.
- Test to ensure we don’t introduce regression bugs for file graphs before merging the db branch to the master branch, I don’t have an estimated date for this one.
I think wee need to have a security release of the only semi-stable version while the DB version is still in development. I know my $5 a month does not carry much weight but with Electron version in use is outdated and marked insecure · Issue #11644 · logseq/logseq · GitHub fixed and a contributor there successfully building and another also building without show-stoppers at Unable to resize window in native wayland with Electron 35.0.1 · Issue #11799 · logseq/logseq · GitHub it seems we can get an interim release so people have a choice other than run an insecure OS and version of Electron, compile their own, or stop using Logseq.
And i think that’s the conclusion in the edit at Understand heads-down on db features, but security/maintenance-releases for deps? (or turn on bot for version bump-PRs to review?) - #7 by londrik as well? So we need to ping somebody with the power to make a tag to release?
