No :block/properties - bug or my fault?
Hi,
I’m quite fresh Logseq user so my problem can be a result of the lack of knowledge, anyway - I have recently noticed that only part of my Tasks is filtered in queries I made (I have separate queries for my own and delegated tasks for which I use property owner:: ).
Searching for possible reasons I found that some of my Tasks has no :block/properties section in block data - you can find an example below:
{:block/uuid #uuid "67bb00ed-5a0b-4b99-a74e-30d37c93af7c",
 :block/left {:db/id 127},
 :block/refs [{:db/id 4}],
 :block/scheduled 20250224,
 :block/format :markdown,
 :block/content
 "TODO some task to be done \nSCHEDULED: <2025-02-24 Mon>",
 :db/id 126,
 :block/path-refs [{:db/id 4} {:db/id 115}],
 :block/parent {:db/id 120},
 :block/page {:db/id 115},
 :block/marker "TODO"}
Editing that kind of task (pressing enter between task and scheduled date) resolves problem (:block/properties {} appears in block data).
  1. Is there any specific reason for such a behaviour (I mean my fault) or can that be kind of bug (I’m not able to reproduce that)?
  2. How can I find tasks with that missing (in my opinion) :block/properties section ?
Thanks
Welcome.
  • Try a query based on this one:
         [?b :block/marker]
         (not [?b :block/properties])
  • It is not clear when :block/properties should be missing instead of empty.
  • If you share your queries, we can possibly adjust them to cover all cases.
Hi,
Your query works fine, thank you.
I assumed that :block/properties should be an element of each block so I’m filtering block based on the following queries:
Delegated
		  (or
 		     [?b :block/scheduled ?d]
 		     [?b :block/deadline ?d]
          [?b :block/marker ?marker]
		  [(contains? #{"NOW" "LATER"  "TODO" "DOING" "WAITING"} ?marker)]
		  [?b :block/properties ?prop]
		  [(get ?prop :owner)]
and my own (in this case today’s tasks) where I don’t use owner:: property:
 		              :in $ ?today
 		              (or
 		                   [?block :block/scheduled ?d]
 		                   [?block :block/deadline ?d]
 		               [?block :block/marker ?marker]
                       [?block  :block/properties ?props]
                       (not [(get ?props :owner)])
                       [(= ?d ?today)]]
Thanks
This one should be as simple as moving :block/properties inside (not ...) , i.e.:
(not
Hi,
Definitely I need to practice queries syntax much more…
Just one tweak makes it all works fine.
With your simple solution it is not important if :block/properties section exists or not - but just to satisfy my curiosity: are there any “rules” when logseq inserts empty :block/properties or doesn’t insert it at all?
Thanks a lot !
That’s characteristic of Datalog. Small (and often accidental) modifications cause big (and often frustrating) differences.
Only the codebase.
