Not able to paste images in whiteboard
I’m using the windows application (version 0.9.0) and it’s not letting me paste or drag a locally stored image in the whiteboard.
I can paste the path to the journal and it renders but no luck on the whiteboard side. Any ideas?
Fixed with the new update!
For some reason I update to 0.9.1 and this error appears, y downgrade and the issue persists, then I update again but it is not solved.
Having the exact same problem. Open Collective contributor, on Windows, using 0.9.1 :sweat_smile:
