Hi there!
I use Logseq with org-mode syntax (on Mac OS) and maybe have found a bug:
I tried to create a book tracker template but as soon as I hit enter after defining a property it gets invisible and a second bullet point appears after it.
In this screenshot I have the properties “title” and “author”, as you can see there is a new bullet point after the empty space where “author” should be:
If you click on that second bullet point the interface turns blank and Logseq seems to crash (can’t navigate back, have to close)
