One thing I miss when I turn to logseq from org-roam is the internal link/Radio Targets.
Radio Target allows you to link any word to a target. One common usage is abbreviation and acronym.
Definition are here:
It looks like internal link with angular brackets is not fully supported in logseq (when you click on link, it does not bring you to the target)
Redio target is not supported at all and the rendering in logseq is incorrect
I know there are alternatives e.g. block reference. But
1> Block reference may failed to render in other org editors. Also failed to render in github org pages
2> It is hard to copy Block references when you have lots blocks with similar name
3> Sometimes I do not need a full block to be referenced.
