Hi,
I have a large Dendron repository full of notes named with dendron’s dot separated hierarchy syntax e.g. aa.bb.cc.md
I attempted to open this local repo with logseq for the first time and saw many errors as shown in the image below
The common theme of all of these errors is that the last section of the hierarchy is the same between two notes. e.g. a note named note1.a.md and a second note named note2.a.md would be considered a naming clash.
Is dendron’s naming syntax incompatible with logseq? Is there a way to migrate a large Dendron repository to logseq without manually updating each filename and its respective note references?
