I have tried AI. Can’t seem to solve the problem. I clicked the setting on the top right. The drop down menu is covered by the Page Title Header.
How do I solve this? I used sticky header plug in, and I think (not sure) the h1 (h2 etc) headers are probably blocked by the Page Title Header so it doesn’t show up.
I tried using default logseq theme, tried disabled Banner plug in. Nothing works. The Page Title just blocks the drop down menu, and sticky header just doesn’t work.
Hi, I ran into the same problem recently(sry it appears i can’t post pictures)
However, to me it is the plugin logseq-toc-plugin v2.1.0 that has caused the problem, while sticky header neither causes the problem nor functions normally. I wonder if you too are using logseq-toc-plugin.
I found that the following codes in the plugin are the reason
