Logseq doesn’t have pages-tree/pages-explorer like Obsidian or Notion. What I want is finding a way to manually maintain pages, below shows the workflow but I failed to write the correct Query:
Any idea? Thanks!
By the way, is there any better way to achieve this, or will Logseq provide the pages-tree/pages-explorer feature? As the pages size grows bigger and bigger, I feel lacking of this feature really push users to the Obsidian.
Welcome.
Could use something like this:
:query [:find (pull ?other [*])
[?p :block/original-name "MyPages"]
[?b :block/page ?p]
[?other :block/original-name]
(not [?b :block/refs ?other])
Most probably yes, but there is no single way. Depending on your exact needs, Logseq can support an appropriate workflow.
Some tree-oriented facility cannot be excluded in the long term, but it is against Logseq’s graph-oriented approach. Meanwhile, check Generate explicit hierarchy out of properties, which contains:
- a specific tool
- plenty of links to other threads that:
- discuss the topic in detail
- provide some alternatives
Thanks for your quick response, and I’ll try the code later today.
Your links for the hierarchy topic are also helpful
