{:title [ :h2 "Missing Pages" ]
:inputs ["concept" "Notes"]
:query [
:find (pull ?p [*])
:in $ ?ptype ?header
(page-property ?p :page-type ?ptype)
[?b :block/page ?p]
[?b :block/content ?bcontent]
[(clojure.string/includes? ?bcontent ?header)]
This is my query so far, it should find pages that both:
- have
page-type:: concept (this bit works)
- have a header (any level) that matches
# Notes
There is at least one page that matches, but it’s not showing, and I’m not really understanding how the last chunk of the where clause should be structured.
You’re right, it is working. My graph was not right
But I’m still stuck, because this query was a stepping stone to a different query, for pages that:
- have
- DO NOT have a header (any level) that matches
# Notes
- (and eventually, so extend that
do not have to include multiple headers (so the search returns any pages that are missing any one of those headers.)
The next iteration the not is stumping me:
:inputs ["concept" "# Notes"]
:query [
:find (pull ?p [*])
[?b :block/page ?p]
(not [(clojure.string/includes? ?bcontent ?header)])
This returns all the page-type:: concept pages, including the one with the # Notes header. I guess because all pages contain at least one block that doesn’t match the header?
Is there a way to find pages where all blocks don’t contain a string?
I tried this:
[?b :block/page ?p]
[?p :page/blocks ?pageblocks]
[?pageblocks :block/content ?bcontent]
(not (some [(clojure.string/includes? ?bcontent ?header)]))
But I got error: Join variables should not be empty, and I don’t have much of an idea how to fix that.
[?b :block/page ?p] ; and there is at least one block in this page
[?b :block/content ?bcontent] ; the content of which
(not [(clojure.string/includes? ?bcontent ?header)]) ; does not include that header
- Should rather make the
(not) wrap the whole paragraph:
(not ; and there is not
[?b :block/page ?p] ; any block in this page
[(clojure.string/includes? ?bcontent ?header)] ; includes that header
Thanks again @mentaloid, super helpful explanation.
The final query I settled on for multiple headers is:
{:title [ :h2 "Pages missing multiple headings" ]
:query [
:find (pull ?p [*])
(page-property ?p :page-type "concept")
(not
[?b :block/page ?p]
(and
[(clojure.string/includes? ?bcontent "# Notes")]
[(clojure.string/includes? ?bcontent "# Related concepts")]
I tried doing a for loop inside the and, but couldn’t make it work. But this solution is good enough for now
I’m using this as a kind of rudimentary documentation-format test, to ensure that all my concept pages conform to a similar structure. I’m sure there’d be nicer ways to do this, but this is very useful.
Urgh, you’re right. However, simply swapping in or doesn’t fix it:
(not ... (and ... gives any page that’s missing BOTH headers
(not ... (or ... gives any page that’s doesn’t have at least one of the headers.
Neither is what I want, which is any page that is missing either of the headers
I think then I need something like (or ... (not ..., , but I don’t know how to structure it. I’ve tried:
(or
[?b :block/page ?p]
(not [(clojure.string/includes? ?bcontent "# Notes")])
[?b :block/page ?p]
(not [(clojure.string/includes? ?bcontent "# Related concepts")])
(I get Join variables should not be empty)
and
[?b :block/page ?p]
(or
all pages get returned.
Not sure if I’m hitting the limits of my clojure understanding or my basic capacity for logic
I think the bit I’m missing is that I need to do something like a clojure filter and make a function for each page in ?p, so that the filter only returns the page ID if the (or .. (not .. clause returns true.
Example pages:
File: test concept all headings.md
page-type:: concept
- ## Definition
- ## Related concepts
- ## Notes
File: test concept no headings.md
page-type:: concept
- blah
File: test concept some headings (missing notes).md
page-type:: concept
- ## Definition
So the above query with an or only returns the page with no headings, where it should also return the page that doesn’t have both headings (the one missing the Notes heading).
Try this:
(or-join [?p]
(not
[?notes :block/page ?p]
[?notes :block/content ?notes-content]
[(clojure.string/includes? ?notes-content "# Notes")]
(not
[?def :block/page ?p]
[?def :block/content ?def-content]
[(clojure.string/includes? ?def-content "# Definition")]
Thanks again @mentaloid, you’re a legend. Yes, that works.
Couple of questions:
- Where do I find information about
or-join and things like it? It’s not mentioned at all in the official docs. I guess it’s from datalog/datomic? If so, does Logseq use the full spec? (this? Query Reference | Datomic - that seems to have an open ended expression-clause which can be a function, though perhaps I’m not reading it correctly.)
- Is there a way to programatically extend that or-join, e.g if I want to make one of those header chunks for each header in a provided vector? For this page template, I only have a few headers I need, so it’s easy. Later on, I’m thinking I’ll want some templates with many headers.
Unfortunately, the answer is the codebase. Compared to Datomic specs etc., some things are implemented, some are not. Datalog itself is not Turing-complete, so some scenarios are impossible. If you have advanced needs, should sooner or later proceed to custom code (consider kits and the likes).
