Thank you! That works great! Do you mind to explain how to update the font if you have a chance?
Sure, you need to open custom.css (itâs in /your-graph/logseq folder or you can open it from Logseq settings) and add the following.
This one if you want to change the font only in Document Mode (the one you activate with t d shortcut (press Esc, then t then d)) like me:
:root :is(.document-mode){
font-family: "Only Emoji", "NewComputerModernMath", "cmr10", "Noto Sans";
font-size: 20px;
Or use this one for the whole page content anyway:
font-size: 20px;
In case you also want to hide block&page Properties in Document Mode:
:root :is(.document-mode) .block-properties.block-properties.block-properties {
display: none !important;
Of course you need the font I linked installed in your system.
I wrote a filter that uses the Pandoc AST. It first reads the Logseq Markdown using Pandoc, processes it to smooth over some idiosyncrasies of logseq itself and of my workflow at the time, and writes out Pandoc again. Itâs not documented, and might not do what you want, but it might be an example to build on.
Thatâs great! Iâll check it out!
Hi! Could you please provide a brief explanation on how to implement it in logseq? Thanks for your kind contribution
Re-upping @alexfazioâs question about documentation. Would love to know how this works.
Hey @Ed_Nico , just curious if there are any updates on this, or if there might even be a timeline if the team did decide to develop this functionality.
Also just to cast my vote specifically for full pandoc integration and handling of logseq markdown idiosyncrasies.
Thank you!
Here is some documentation about the script: GitHub - Tamriel/logseq2pandoc: Export Logseq pages to PDF or epub
The logseq-pandoc-plugin converts your pages and blocks to different formats using Pandoc.
Supports:
- docx
- pptx
- html
- latex
- citations
https://github.com/benjypng/logseq-pandoc-plugin/blob/main/screenshots/demo.gif
Thank you for the plugin, it helps for initial .docx conversion! (Although requires manual activities in Word after it.)
I shared some enhancement ideas (and an issue) in Github, maybe these can be discussed here if needed / appropriate, as I havenât found a Github discussion page for this repo.
Hey, thanks for pointing us at logseq-pandoc-plugin.
Generally looks cool, but itâs not really working well for me:
- Doesnât finish for large docs. Crashes?
- Doesnât understand some Logseq-specific MD syntax and just prints it, which looks ugly.
- Doesnât actually export to PDF, just Word, PPT, HTML, LaTeX. (yes, you can covert again from there)
With logseq-pdf-export-plugin I also still see a bunch of proprietary MD markup in the output (like list bullet format), and some LaTeX formulas are shown in the source code, not rendered.
What worked better for me was âPdf Printâ (logseq-plugin-pdf-print).
It just exports/prints the whole page as-is. That includes some UI, and margins etc. So not.a perfect print layout, but it works fairly well when:
- Use Document View
- Toggle Wide Mode
- Expand all blocks
- Scroll all the way to the end to render the full page
Any other suggestions that I should try?
Kind of odd, that PDF export/print isnât built in.
Hi, this is the manual way I found to generate pdf document with the Eisvogel pandoc LaTeX template (available on Github: enhuiz/eisvogel) from a Logseq page:
Steps
- Add a YAML metadata at the top of your markdown document.
At the beginning of your Logseq page, add a YAML metadata block. This block defines information about your document, such as title, author, and date and formatting options
Example:
title: "Logseq page to pdf"
author: [jfxs]
date: "27-12-2024"
titlepage: true
toc-own-page: true
- Fix deep nesting error:
To avoid a LaTeX error related to deep nesting, create a file named deeplists.tex inside your Logseq pages directory (usually located at `your_logseq_data_dir/pages). Add the following content to the file:
\usepackage{enumitem}
\setlistdepth{9}
\setlist[itemize,1]{label={}}
\setlist[itemize,2]{label={}}
\setlist[itemize,3]{label={}}
\setlist[itemize,4]{label={}}
\setlist[itemize,5]{label={}}
\setlist[itemize,6]{label={}}
\setlist[itemize,7]{label={}}
\setlist[itemize,8]{label={}}
\setlist[itemize,9]{label={}}
\renewlist{itemize}{itemize}{9}
Optional: To keep bullets on every line, replace label={} with label=\textbullet in the code above
- Generate PDF using
pandoc
While using Docker isolates the environment and simplifies dependency management, you can also execute pandoc directly if you have it and its dependencies installed locally.
cd your_logseq_data_dir
docker run --rm --volume "$(pwd):/data" -w "/data/pages" pandoc/extra:latest-ubuntu -V mainfont="DejaVu Sans" --from markdown+emoji --pdf-engine=xelatex -H deeplists.tex --template eisvogel --toc -N -o your_logseq_page.pdf your_logseq_page.md
I have tested the creation of pdf files from my LogSeq graph. The created pdf files look good. Unfortunately, it does not work perfectly for me. The title and the author are not taken from the YAML metadata. Also, additional blank lines are inserted in some places, especially between successive headings and after each heading.
What could be the problem?
Environment: TexLive is installed locally and the creation with
pandoc -V mainfont=âDejaVu Sansâ --from markdown+emoji --pdf-engine=xelatex -H deeplists.tex --template eisvogel --toc -N -o your_logseq_page.pdf your_logseq_page.md
