PDF Export using Kits?
The existing PDF export plugin seems to no longer work properly. It’s only rendering 1 page. Is there a new way to do this? Can KITS be used?
In theory, any plugin can be implemented as a kit. However, someone has to do all the work of converting it. In any case, fixing a broken plugin should be easier than converting it.
Makes sense. Praying that exporting features get improved soon.
