Performance issue on Sonoma 14
Hello everyone,
I wanted to ask if any of you are experiencing the same performance issues in Logseq that I am currently encountering. My computer is a Mac Studio with 64 GB of memory 10cores, running macOS 14 with the latest version of Logseq.
What I’ve been noticing is that when I try to resize the Logseq window by dragging from a corner to make it larger or smaller, the performance is quite poor. It has reached the point where it takes several long seconds for the content inside the window to adapt the content to the new window size.
I have tried resetting Logseq, disabling all plugins and switched to the default theme, but I still encounter the same performance issues.
Here’s a loom to demonstrate what I’m referring to: Loom | Free Screen & Video Recording Software | Loom
Is anyone else experiencing this? Could this be related to Sonoma / Electron?
cheers
Did this ever improve with any update to LogSeq or MacOS? If it did can you please share which versions of either or both improved this?
