PLEASE - Need help importing my graph from Reflect Notes
I’ve somehow imported Reflect graphs before (from json files exported from Reflect). Now I try and it pulls in nothing. I’m using the desktop app (Silicon) on an M1 Mac Mini. Here’s what I did:
  1. In Reflect exported the graph (about 3000 files) by choosing Reflect JSON export format.
  2. In LogSeq, created new graph; chose Import from the pull-down menu in upper right hand corner (•••); chose the EDN/JSON option and then selected the json file from the Reflect export.
  3. Immediately see “Import finished!” message, but find no imported files whatsoever.
Other threads suggest pulling in Markdown files, and I can’t find a way to do that either.
Desperately need help as my (two-month) trial with Reflect left me wanting to return to Logseq.
Extremely grateful for any help.
Thanks,
David Dobbs
Vermont
Having the same issue importing from Mem.
Follow all the same steps and have same result!
Curious, did you ever solve this? I’m trying to figure out the best way to move from Reflect, but not sure what else understands their json format.
