Is it possible to use the API to make a simple plugin that, for example, replaces :hw:
in every block with Hello World!
at render time (i.e., keeping the original file with the :hw:
), without using any slash command? Just installing the plugin and every instance of :hw:
visible is rendered as that other string. Of course, the rest of the text should keep standard markdown render.
I tried to use onBlockRendererSlotted, but I don’t understand the docs and I haven’t found any examples on rendering the Markdown. I then tried using provideUI
inside, but it receives HTML. Can I use Markdown instead?
