Some plugins offer keyboard shortcuts or a slash command but how to use these is only available on GitHub on the README for each plugin. It would be great if a short help text could be exposed inside Logseq.
You can acces the readme directly from within ligseq by clicking the plugin icon. That may be relevant to your request. Also, all keyboard shortcuts can be found in the command pallete unless the author of the plugin explicitly opts out of that.
I’ll check it out, but it could be made clearer.
