Plugin to color graphs differently
Hi folks!
Is there a plugin which would make different graphs look differently, like for instance with colors.
Currently there is the Accent Color thing, but it’s a global configuration so it applies to all the graphs. I need almost the same but
  • with per graph settings
  • with coloring backgrounds as well, because links are definitely not enough.
Is there a plugin for this?
