Hi,
I’m facing an issue with Polish characters. Any idea what’s the root cause and how to solve it?
My theme: Laurel theme.
Hi,
Does the issue exist in the default theme?
Well, it does not. Thanks for the suggestion!
Do you have any idea how to solve it for this particular custom theme?
Most likely the theme uses a font that doesn’t support Polish chars well.
you can override the font if you like or use another theme.
Alright, thank you for the explanation! ![]()
