Problems with PDF reader on both mobile and desktop
Hi do the particular problem I’m having in the logseq environment is that PDFs won’t open both on my laptop-> desktop version and-> mobile - android 13
  • On desktop I continually get file path errors using shift + click and my default pdf reader isn’t opened when embedded either, even when the pdf file is first out in the assets folder and referenced directly
  • On mobile a click seems to try open the file and then nothing happens
  • For comparison purposes I tried the same processes in Obsidian on both mobile and desktop and the PDF reader opened seemlessly indicating to me I might be missing a small detail on how to set it up and I’m so keen to use loqseqs annotations and just have that in one place
How would I get the pdf reader to actually work so I can use it in my workflow
