I wanted to make a definition list for all properties that I use. And I wanted a way to check for any properties not on the list.
Learning some clojure along the way
here’s the result.
On my workflow page, I have a section for property usage. It looks like this (collapsed blocks also have property lists as children)
The idea is to give a definition as the value. Alternatively you can put the definition beneath the property if you don’t want it to show up in the auto completion list.
There’s a query here “Andere Properties” which will list any properties not currently on this page. (system properties contain such properties as icon and file)
{:title [:b "Andere Properties"]
:inputs [:query-page] ; input the page the query is on for use in the query
:query [:find ?prop ?def ; find the properties list and the definitions list
:keys prop def ; put the find items in specified keys.
:in $ ?page ; definition of the query-page input
[?w :block/name ?page] ; get the database item of the query-page
[?b :block/page ?w] ; get all blocks on the query-page
[?b :block/properties ?def] ; fill variable ?def with the available block properties
[?p :block/journal? false] ; get all non-journal pages
[?p :block/file _] ; only those pages that also have a file = have content
[?p :block/properties ?prop] ; fill variable ?prop with the available page properties
(not [(empty? ?prop)]) ; filter out block property lists that are empty
:result-transform (fn [rows]
(def proplist (set (distinct (flatten (map keys (for [r rows] (get r :prop) ) ) ) ) ) ) ; from the result for properties get a list of unique keys
(def deflist (set (distinct (flatten (map keys (for [r rows] (get r :def) ) ) ) ) ) ) ; do the same for the result for definitions
(sort (remove deflist proplist) ) ; subtract the deflist from the proplist and sort the result
:view (fn [rows] (for [r rows] (str/replace (str r ". ") ":" "") ) ) ; add a . to the end of each item and remove the : from the name. This results in a single line as icon. file. etc.
Example result
Alteration options. (feel free to let me know some alternative scenarios to consider)
Properties list based on block properties instead of page properties
Change:
To:
[?h :block/page ?p] ; get blocks of the pages
[?h :block/properties ?prop] ; fill variable ?prop with the available properties of those blocks
Result as list instead of single line
Change:
To:
:view (fn [rows] (for [r rows] [:div (str/replace (str r ". ") ":" "") ] ) ) ; add a . to the end of each item and remove the : from the name. The [:div ] turns this result in a list of items.
List of system properties
To help you filter them out
these are the ones present in my graph, feel free to point out some I’ve missed.
collapsed::
exclude-from-graph-view::
file::
file-path::
hl-color::
hl-page::
hl-stamp::
hl-type::
ls-type::
icon::
public::
query-properties::
query-sort-by::
query-sort-desc::
query-table::
template::
template-including-parent::
