it would be nice to support properties formatted as unordered lists like:
property1:: this-works, great property2:: - value1-of-property2 - value2-of-property2 - value3-of-property2
or maybe without the dash, but using tab instead ? eg:
property1:: this-works, great property2:: value1-of-property2 value2-of-property2 value3-of-property2
not sure which syntax would be the best, the idea is to enable lists to improve readability
another suggestion: support for tabs as delimiters, also as en effort to improve readability (any number of tabs would be accepted) :
property1:: value1 value2 value3 property2:: would be nice property3:: [[this is]] [[just an example]] [[thoughts ?]] numbers:: 13 564 2045
which would be equivalent to
property1:: value1,value2,value3 property2:: would,be,nice property3:: [[this is]],[[just an example]],[[thoughts ?]] numbers:: 13, 564, 2045
my initial idea was to request support for both ‘edit mode’ and ‘display mode’, but I wonder if that could be only a ‘display mode/rendering’ option ? (probably easier to implement this way, but it would create more inconsistencies between editing and reading)
