Hi folks!
I’m learning the query language and I wonder how to make a query with an optional exclusion.
So I need to get all the #note blocks that have TODO marker set, but exclude those which I’m currently working on in the current day in journal.
{:title "🔨 TODO notes"
:in $ ?today
[?b :block/marker ?marker]
[(contains? #{"LATER" "TODO" "DOING"} ?marker)]
[?b :block/refs ?tag]
[?tag :block/name "note"]
[?b :block/page ?page]
[?page :block/journal? true]
[?page :block/journal-day ?date]
[(!= ?date ?today)]]
:inputs [:today]
:group-by-page? false
:collapsed? false
In this query I constrain :block/page to be journal. But I need to express:
if this block is in journal, then
apply the date condition
otherwise
ignore the date condition
How to do that?
UPD. I found a related thread: Query incomplete tasks which are not referenced from a specific page
I believe that approach is quite good: instead of checking the date, I can simply exclude blocks, that don’t belong to the current page - the journal day page.
In this case my condition changes to:
if this block belongs to the current page
exclude it
otherwise
include it
Try this:
(or-join [?today ?page]
(not [?page :block/journal? true])
(and
[(!= ?date ?today)]
I assume you just want to say:
- Don’t show tasks that are in current journal
We can just make it a “complete” not statement.
So:
(not
[?page :block/journal-day ?today]
It basically works like this:
- We create a subset which is #note TODO blocks that are on today’s journal page
- Then we say, from the whole set, subtract this subset
If that makes sense?
Edit, for clarity, the complete query is:
:in $ ?today
(not
:inputs [:today]
:collapsed? false
Maybe I did something wrong, but I get an error
Insufficient bindings: none of #{?page} is bound in (not [?page :block/journal? true])
with this query:
{:title "🔨 TODO notes (mentaloid)"
:in $ ?today
(not [(contains? #{"DONE" "CANCELED" "CANCELLED"} ?marker)])
(and
[(!= ?date ?today)]
:inputs [:today]
You removed this needed line:
Thanks, it works exactly as I wished. And simple exclusion as you noticed is really what was required in this case
Exactly! Thank you!
Well, that answers my question how I phrased it.
Nice to see a solution using or-join while I was thinking in SQL’s lef-joins
Difficult to pick the right solution as both solve my problem.
@Siferiax I like your solution more and will use it, but will pick the mentaloid’s answer as it literally answers my question.
both are correct indeed.
My solution is more straightforward.
However, the one from mentaloid can be adapted to make a more complex query. For example the todo is not on a journal page, or on today’s journal page.
I think both have value.
I have a similar issue but I want to exclude tasks that are on pages with a specific property.
I use a property called “function” and I want all TODO tasks on those pages where function is episode to be excluded from the following query.
I can’t quite figure out how to use Mentaloids version above to get at this.
:title [:b "Unscheduled Tasks"]
:where [?b :block/marker ?marker]
(not [?b :block/scheduled ?sch])
(not [?b :block/deadline ?sch])
[(contains? #{"TODO" "DOING"} ?marker)]]
I don’t see how the two issues are similar, but maybe you are looking for something like this:
(not
[?b :block/page ?p]
[?p :block/properties ?props]
[(get ?props :function) ?function]
[(= ?function "episode")]
